Stage 1...how much psi?
Old Apr 8, 2011 | 12:22 PM
gmdealerguy's Avatar
Mine has hit 24 and 26 (mainly right after I had the kit installed)a few times but most of the time I am between 15-22 pounds.
Old Apr 8, 2011 | 05:52 PM
hyperv6's Avatar
Offically as I recall the GMPD engineer said that the top limit really is 23-24 PSI no matter what the gauge says.
Note I have seen a little more too but I think it bounced up as it was just a flash on the digital boost gauge and not a sustained level.
Old Apr 8, 2011 | 06:16 PM
I consistantly see 17-23 with the occasional blip to 25. This is in regular mode (not comp. mode).
Old Apr 8, 2011 | 06:39 PM
gcsd3742's Avatar
I've hit 30 PSI but of course it goes into limp mode....but we bumped it back down to 28 PSI max.....
Old Apr 9, 2011 | 12:42 AM
IgottaWoody's Avatar
I see 25 regularly too.....maybe because I'm close to sea level....
Fun with numbers...when you add in the "normal' sea level pressures of 14.7 on top of the 25 you get.........try that next time at Sonic! Eyeballs will pop right out!
Old Apr 11, 2011 | 11:33 AM
terryk's Avatar
Mine pretty much hits 20 consistently. I have seen more (like around 23-24) but I don't know why and it doesn't happen often enough to figure it out. I suspect it's related to elevation.
I have noticed that rolling into the throttle seems to give slightly less boost than a quick stab to the floor.
Doctor Who
2.0L Performance Tech
Nov 2, 2011 12:44 PM
JRGHHRSS08
17
Feb 23, 2011 12:19 PM
Sandmanse7en
18
Nov 21, 2009 09:21 PM
2001ssboosted
30
Apr 10, 2009 07:38 AM
camaro98z28
30
Jan 6, 2009 10:07 PM
