Chevy HHR Network
-   2.0L Performance Tech (https://www.chevyhhr.net/forums/2-0l-performance-tech-46/)
-   -   Torque specs for zzp stage 4 clutch?? (https://www.chevyhhr.net/forums/2-0l-performance-tech-46/torque-specs-zzp-stage-4-clutch-42301/)
shortonmoney2 Aug 10, 2012 06:21 PM
What are the torque specs for oen flywheel and zzp stage 4 clutch??
American & Proud Aug 10, 2012 06:40 PM
Might have better luck contacting ZZP for that info.
:skull:
shortonmoney2 Aug 10, 2012 07:12 PM
:skull:
I did never got an email back and i know a few members have one
RobSSTurbo Aug 10, 2012 09:44 PM
Talk to joe schulte he has one in his HHR SS. The flywheel bolts to the crank is tq to yield and the flywheel bolts to the clutch are reusable.
American & Proud Aug 10, 2012 10:12 PM
:thumb: Well hopefully you find your answer soon.
Good luck. :cool:
:skull:
RobSSTurbo Aug 12, 2012 04:37 PM
When tightening down the flywheel bolts use a star pattern and also torque down in stages. First torque to ~15ft/lbs and then go back around and torque to the full 39ft/lbs plus an additional 25 degrees. Thats if you are using the factory bolts.
