Turbo maintenance and tips
How's going all, proud to say I'm a proud new owner of my own HHR SS. I was just think about a possible sticky thread for, "turbo maintenance and tips". I have never owned my own turbo car and know that they have some specific needs that need to be meet in order to operate properly . So any pro's on the matter I would really appreciate it if you could chime in, and help out me and anyone else that could use help on the matter. Thanks
Suggestions
-Oil type
-When to change oil, by cars in dash info or set miles i.e. 2500 or 4500?
-Allowed cool down period, is it necessary if the car will only be shut down for a certain amount of time, i.e. 5 minutes compared to 8 hours?
-Any other advice
Happy 4TH
Suggestions
-Oil type
-Any other advice
Happy 4TH
Turbos get hot... and so after spirited driving, it's a good idea to idle the car for a few minutes (2-3) to allow the turbo to cool down while the oil is still cycling through the system. If you turn off hte engine while a turbo is ultra-hot, the oil inside the unit can boil into a gunky coke (not the soft drink, nor the drug) substance. That's not what you want in your tubo.
I haven't actually bothered to peek under the hood yet (too busy with work, move, etc., since I got the car
), but I doubt it. I'm not aware of any turbo that uses water cooling. Most turbos are either self-contained oil-cooled or recirculating oil cooled. I'd expect that water just couldn't hold up to the heat.
Your KO4 Turbo is watercooled. It's pretty much standard these days on turbos.
The factory recommends 5w30 Mobil 1. Any of the name-brand synthetics are up to the task, but I'd stay away from the second-tier stuff...we've seen issues with oil coking with some of those brands. In any case, make sure what you choose meets the specs called out in your owner's manual.
