2.2 ecotech Obd2 will not read any codes
Old Apr 30, 2025 | 07:41 PM
OrtizAuto's Avatar
So I started having issues with my Obd2 and I replaced fuses several times. I have to run vehicle to set monitors yet every time I run it Obd2 Goes kaput on EVAP monitor. Does anyone think it can be the actual fuse box and it might be an actual short on the box itself?
Old Apr 30, 2025 | 08:35 PM
Please rephrase; I don't understand.
If the code reader is not getting a connection at all (like your title states) then the cigar lighter fuse in the under hood fuse box is probably blown. Does the front cigar lighter have power?
Old May 1, 2025 | 04:50 AM
Is this a HHR ? Doesn’t say make, model or year. Even his bio is blank.
Old May 1, 2025 | 07:11 AM
Tighten the 4 , 7mm bolts in the under hood fuse box and push all the fuses and relays firmly into position.
Paw8urmom
Oct 5, 2023 10:10 PM
firas
Oct 18, 2021 03:27 PM
mnsteel
2.2L Performance Tech
Jul 16, 2018 10:14 AM
tjsaudio
Jul 2, 2016 09:32 AM
stanvalp
Feb 27, 2011 09:29 PM
