2.2 engine swap interchangeable
Old Aug 25, 2023 | 07:45 PM
I’m thinking you could try assembling the 2010 block with the 2007 head and check clearance to the pistons and valves, check the head gasket to the block and the head. Use the 2007 cams and cam sprockets. See if it works, if it does post it here , let us know
Old Aug 25, 2023 | 07:55 PM
PulpFriction's Avatar
You haven't said what's wrong with 2007.
Old Aug 25, 2023 | 09:40 PM
Not sure which head gasket you'd need. 1 fits the head, 1 fits the block. Although they look nearly identical. 1 seems to have 4 holes outside of the timing chain opening, the other I only see 2.
Old Aug 26, 2023 | 11:21 AM
The 2 posted in this thread look identical to me, just flipped L/R. IIRC, the difference between 2.2 VVT and 2.4 VVT is the stroke, bore is the same. Difference between VVT and non-VVT is the VVT valve holes
Old Aug 26, 2023 | 10:24 PM
PCMFHHR's Avatar
Found some problems
Old Aug 27, 2023 | 03:44 AM
PCMFHHR's Avatar
Carnage
Found some parts.
Old Aug 27, 2023 | 06:15 AM
We don’t charge by the word. You could add a few details and tell us what you’re not saying.
Old Aug 27, 2023 | 07:42 AM
Carnage? Like bent valves? In which engine, 07 or 10? New valves might resolve the issues , photos help.
Old Aug 27, 2023 | 10:23 AM
PCMFHHR's Avatar
Old Aug 27, 2023 | 10:25 AM
PCMFHHR's Avatar
It has valve contact marks on all but 1 piston.
