2.2 Timing Chain Replacement Frequency
Old Nov 19, 2025 | 05:34 AM
m_ridzon's Avatar
Me personally, I have officially given up on Cloyes. Their products have cost me enough money and headaches. So I'll likely buy the chain kit from GM and the upgraded ZZP front guide. I already have the stronger upper guide bolt installed, so that's no issue. I'll inspect my balancer chain and see if it needs attention too.
Old Nov 19, 2025 | 06:26 AM
While you’re in there change both chains. Don’t be upset if the GM chain was made by Cloyes.
https://a.co/d/2lriDsi
The GM AC Delco kit
Old Nov 19, 2025 | 12:35 PM
Gearhead1's Avatar
Have 2011 hhr 2.2….bought car with 109,xxx on it…now has 280,xxx. I bought a EVERGREEN timing kit that included the waterpump. Waterpump seals did fail at about 80,000 miles on it but chains and guides are still same I put in it. Most of the miles are interstate, constant speed miles. I do need to check chain for slack again….figure its due.
I actually modified the waterpump timing tool so there was no way the chain could get any slack.
Old Nov 19, 2025 | 01:37 PM
I installed an Evergreen kit I bought off EBay for a bid of $35. It stretched at 20,000 miles I had to replace it
This was that chain at only 20,000 miles
Old Nov 19, 2025 | 01:44 PM
Gearhead1's Avatar
I remember you telling me about that
Old Nov 19, 2025 | 01:47 PM
I can only share my experience with these problems
Old Nov 20, 2025 | 12:53 PM
Gearhead1's Avatar
currently at 281930 miles,….new chains and guides were at 109,xxx. Front guide looks good as far as I can tell.
281,930 miles
281,930 miles
Old Nov 20, 2025 | 08:02 PM
Top guide looks great chain is nice and tight.
Old Nov 20, 2025 | 08:10 PM
Gearhead1's Avatar
I change oil regularly….most all miles are interstate constant speed…
Old Nov 21, 2025 | 06:55 AM
Do you have that front guide upper bolt replaced with the stronger bolt?
