2007 LT Throttle Body Relearn Process
Old May 1, 2021 | 12:33 PM
Fire_Wessle's Avatar
Originally Posted by Oldblue
Well first off, did you disconnect the negative battery terminal ?
Did you try to move the throttle plate manually?
What brand of throttle body did you get?
I did disconnect it from the negative terminal, I did not try to push on the plate, and it is a Bosch part from rock auto
Old May 1, 2021 | 02:32 PM
I have tried the relearn procedure multiple times to no avail. It starts out at 2000 then sometimes dips to 1700 then climbs to 2500. I have no idea what to do
Old May 1, 2021 | 05:37 PM
Try another battery lobotomy.
Old May 6, 2021 | 09:51 PM
Sorry about the late response, I had to revert back to the original throttle body. I going to talk to my mechanic and see if he has any ideas. No clue when that will happen but I'm sure I'll post again at some point. Go ahead and close this thread if you would like
Old May 7, 2021 | 06:34 AM
Well if you’re not gonna try what we suggest, might as well close this!
qcswlal
Jul 12, 2024 11:24 AM
Optimistic
Jul 5, 2024 06:59 AM
michael sovern
May 29, 2019 11:37 PM
hhr06NJ
Aug 10, 2014 08:23 PM
hhrrws
May 15, 2013 10:33 PM
