2008 HHR 2.2. Suddenly having multuple codes and profirmance issues.
I had a few strange things start happening with the 2008 HHR. First it would crank or attempt to start. battery was good and lights all worked. Then it would start fine. Next day temp gauge was zeroed out and ac was out. Next day I went to take it in but it was fine. Then it started loosing power and then suddenly surge and accerate. Then engine light came on. Had codeas checked and from codes and syptoms, it was recommended I change the MAF. changed MAF and it didn't change a thing. Had codes read again and it came up qith a laundry list. of 12 codes. Reset EMC and drove around but no engine light and no codes but still having surges of powr and loss of power
You probably should have put down the whole laundry list of codes. Even I can look them up for you and give you a better educated guess as to what is wrong with your buggy that way.
It has been my experience that you rarely need to actually replace the MAF {Mass Air Flow sensor} usually a good cleaning and making sure you have I properly hooked up is good for them. Naturally if it is broken or otherwise destroyed it does need to be replaced.
I do wish you luck fixing things, post the actual code and others will help.
How do, where did you have the battery load tested?
You should also inspect the underhood fuse box halves.
Welcome to the site.
Multiple codes like this usually point to a dying battery, loose or dirty ground connections and rodents dining on the wiring harnesses
i feel your pain i have a cherry 08 2lt thats doing the same thing , i,v done so much and it still throws codes and u clear them and within a day or 2 it goes crazy dic gets crazy with codes and speedo gauges bounce all over the place , keep us posted hope u find the prob wish i could ,,,, welcome also
06chevyHHR
Apr 18, 2013 06:03 AM
venomlegionsHHR
Jul 5, 2012 10:54 AM
to the forums!!
