89 octane... bah
Thought I'd experiment with putting 89 in Cobbs just in case GM was a little aggressive on spark advance in the ECM.
Well, turns out it ran better on 87. Unprecise proof that the GM factory tune on the 2.2 is pretty dialed-in for 87 reg unleaded. As we know, using a higher octane in an engine tuned for 87 can actually cause a slight performance hit, similar to slight retardation in timing.
Now I need to burn off this tank of 89.
Experiment was a success, though, because it loosely proved what I suspected-- running mid-grade or higher in the 2.2 won't help at all and will even simulate a slight reduction in spark advance.
I posted a link to some info on octane here...post #8
https://www.chevyhhr.net/forums/2-4l-performance-tech-14/what-octane-use-hhr-10163/
octane is basically how fast the fuel ignites. A higher octane rating means it ignites slower. Lower octane ignites faster. Thus using an octane higher than what is optimal for your engine's spark programming (spark advance throughout the rpm range, usually vs. MAP value at a given rpm) can do the same thing as reducing (retarding) the timing (spark advance). Retarding spark advance when you don't need to (i.e. when there's no knock or "ping") will cause a decrease in performance.
It all depends on how the spark advance tables are programmed, so there probably is room to increase spark advance throughout the timing tables in the ECM to take advantage of higher octane fuel.
sweetmama, it could be the fact that we're using "summer blend" now. I thought I read that it will reduce mpg. Has your station recently added ethanol to their blend? That will negatively affect your mpgs also.
bigjacksauto
2.0L Performance Tech
18
Jul 25, 2012 10:40 AM
