zzp 2.2 turbo clearance problems?
looking down you can see the alternator, radiator overflow and sheet metal. Very little room.
Looking for someone with a 2.2 zzp turbo kit ….need some help. I have most of it installed but the tube on the passenger side from the intercooler to the throttle body has no place to go. Anybody else with this problem and if so what did you do?
All zzp will say is "you need some custom fabrication". Cutting sheet metal is something you can't back out of...
any ideas?
danny
I don't know about the ZZP kit..On an SS the throttle body is on the bottom of the manifold, so the pipe is routed through a different spot.
lilbloohhr
12-23-2006 11:40 AM
