Cost to rebuild 2.2 liter flex fuel engine
Welcome to the site.
If it " threw a rod", it probably can't be rebuilt. Thrown rods will usually damage the engine block beyond repair.
Look at getting a used or remanufactured engine. Prices will vary.
Welcome to the site , this might be cheaper than rebuilding
https://m.summitracing.com/parts/nal-19177026
My apologies, I found this for the 2011 LE8 for used engines
2011 Chevrolet HHR 2.2L (Fits: 2.2L (VIN W, 8th digit, opt LE8) Used Engines For Sale @ BUYUSEDENGINE.COM Buy cheap Used engines at BUYUSEDENGINE.COM)
I live In Southern Cali and some how destroyed my motor driving back home from Northern Cali. My mechanic found a motor for around 900.00 that had 32k miles and he said was clean. Then pulled the old motor and installed the new motor for 2850.00 out the door. Lucky for me I was working an overtime job. So all my extra fun money went into a newer motor but so far it runs good and I've put 6k on the newer motor.
So, how much labor do you guys think is reasonable for the engine swap if you provide the replacement engine?
I'm usually around , three cups of coffee, lunch, a nap in the afternoon, then dinner, back at it till 1 maybe 2am , so I don't know what the book says is correct, I remember 15 hours mentioned once before x what ever your mechanic charges!
