O2 sensor question
Old 01-10-2019, 07:57 PM
comandoed's Avatar
O2 sensor question
Originally Posted by donbrew
If it will run with the stock tune, that seems like the easiest.
I think the O2 sensor monitors runs continuously or twice a drive, so I don't know how it could "be not ready".
I suppose you could try a battery disconnect lobotomy.
What is stock tune? I have same problem. O2 Sensor : Incomplete also Evaporative Sys: Incomplete
comandoed is offline
Old 01-10-2019, 08:01 PM
Sounds like your issue is for a 2.2 or 2.4, this thread pertains to the 2.0 Turbo SS
Oldblue is offline
Technical Moderator
"Not ready" means that the OBD2 test for the O2 sensors has not run. Did you disconnect the battery or clear codes recently?
What codes did you cl;ear?
donbrew is offline
Old 01-11-2019, 01:07 AM
comandoed's Avatar
Just bought wagon 4 days ago.
Old 01-11-2019, 01:57 AM
comandoed- no one can really help you much unless you answer the questions raised to help diagnose the problems you are having.
Ie: Donbrew has asked two questions that you even quoted, yet you did not supply any answers.
whopper is offline
Old 01-11-2019, 06:37 AM
comandoed's Avatar
Please follow thread more carefully. I am not asking for help. My initial question was "What is stock tune?". I was trying to simply educate myself.
The answer to his question, I thought was implicit when I replied that I had just bought the car 4 days ago and that that is how the car came.
I commented about my "incompletes" for conversation sake only. Maybe I should not have.
At this point I am not asking for any help. Sorry for the misunderstanding!
Old 01-11-2019, 07:27 AM
Yes comandoed, please follow the "thread" more carefully.
This is a thread about the SS HHR. (it is in the SS specific forum) Your bio shows you have a 2007 so it is not a SS.
You stated : quote "I have same problem. O2 Sensor : Incomplete also Evaporative Sys: Incomplete" To me, that reads as you've got a problem and you're looking for help.
firemangeorge is offline
Old 01-11-2019, 08:00 AM
Technical Moderator
Stock tune is what comes from the factory.
BTW, I did follow the thread. Your first post was #6 and stated "same problem" but evidently is not.
Bye.
donbrew is offline
Old 01-11-2019, 10:23 AM
Thread separation, moved this to the 2.2 files.
Oldblue is offline
2005HHRauto
06-14-2012 03:48 PM
lake
08-10-2008 07:59 AM
Quick Reply: O2 sensor question
