Airaid Cold Air
Old 10-04-2011, 02:22 PM
chichi's Avatar
Question Airaid Cold Air
Not sure if anyone has posted anything on this but has anyone installed an "Airaid" cold air intake on their hhr? Does it make any noticable differences, Does it play havic with the mass air sensor? Any pics of the installation? Thanks for any reply.
chichi is offline
Old 10-04-2011, 09:37 PM
Seca650RJ's Avatar
Ran one for over a year. decent mod, performance gains are negligable but it does sound good when you get on the throttle. Automatic 2.2 motor only, will fit a 5 speed but will run into interference with the hood insulation. Best intake mod out there though. CGS and WeaponR soak too much heat in the warm weather and K&N doesn't offer a kit for the 2.2 motor. Hope this helps.
Seca650RJ is offline
Old 10-04-2011, 09:53 PM
jay loukakis's Avatar
check on site socalhhrs.com did a tesy stock CGS and airraid
jay loukakis is offline
Old 10-05-2011, 12:45 AM
TiggersHHR's Avatar
I would not say it DOES NOT FIT a 2.2 with a 5-speed.
I have such a critter and I have one on mine - occours I only ordered the tube, filter, and screws for MAS.
I made my own mounting bracket and I do not use the box.
Below are just Two pics from my Gallery.
Like "Seca650RJ" said - performance gains are negligable, but it does have one hell of a nice sound when you get on it.
TiggersHHR is offline
Old 10-05-2011, 07:06 AM
BlackScreaminMachine's Avatar
Like any modification its good support for future ones. Also since its a smaller motor guys like me used to LSx gains for a cold air "lid" could get disappointed but I learned my lessons long ago.
BlackScreaminMachine is offline
Old 10-08-2011, 08:03 AM
chichi's Avatar
Thanks for the responses. Thinkin' of going with CGS.
chichi is offline
Old 10-08-2011, 04:57 PM
wikdlit's Avatar
I have the K&N FIPK #57-3056 (sold for the 2.4) on my '08 2.2 HHR. There is one modification needed to make it fit, apparently the threaded holes atop the valve cover vary between the 2 engines. There are 4 pre-drilled holes on the base of the closed box that the filter fits in. One, and only one, of those holes doesn't line up. So simply measure the threaded holes on the valve cover for their location, mark & drill a new one on the filter box base, and you're done. Ridiculously easy, all K&N has to do is sell the same number kit with one extra super tiny hole, and the kit fits both engines. I sold K&N for 10 years, installed a number of 'em too, and this kit is a good one. The enclosed box that the filter fits in is a nice thought. Maybe not the same punch as the CGS, but still pretty sweet.
wikdlit is offline
Old 10-08-2011, 08:13 PM
I had the CGS, then modified it and put a 10 inch Edelbrok filter, performance gain over the stock CGS,
Old 10-08-2011, 10:16 PM
my air box
sleeper is offline
Old 10-09-2011, 02:56 PM
VinceP's Avatar
I have to ask, maybe a dumb question or maybe it makes no difference, but arent you pulling mostly hot air from the engine bay on this setup?
VinceP is offline
Quick Reply: Airaid Cold Air
