headers
Has anyone install a header I was looking under are car it looks like a mother to change out the header. those who installed a header can you post what kind and tell how long did it take to install and was it a pain in the butt.
Piece of cake maybe 30 minutes you have to go under the car and undo 2 bolts at the flange all the rest you do from the top and the header comes out from the top all so.
I pulled mine last spring polished and ported it and put it back in big difference and you don`t have to wory about fit or leakage problems. |
Cool!
Originally Posted by GTOMIKE
(Post 344362)
I put a header with race down pipe on mine in less than 45 min. on a rack.
Had to remove the air box off the top to tighten 2 of the bolts from the top. I could reach them from the bottom but it was difficult. |
Originally Posted by catdaddy137
(Post 344388)
if you are talking about the stock exhaust , what did it look like in there? was there alot of extra material from where it came out of the mold-from casting? did you match it too the gasket? i used to do it to 2 cycle scooters , with those little engines it was amazing how much difference just a little cleaning up would make. it seemed like the intake made more difference. alot of people would take too much out of the exhaust , lose backpressure and power. i don't know how much backpressure is needed on 4 cycles , i don't think they need much. have you ever seen dimples in those old 60s chevys exhaust pipes ? i wonder if they made a difference?
[QUOTE=catdaddy137;344388]if you are talking about the stock exhaust , what did it look like in there? was there alot of extra material from where it came out of the mold-from casting? did you match it too the gasket?QUOTE]
Yes stock manifold is very restrictive take a look here. https://www.chevyhhr.net/forums/2-2l-performance-tech-5/how-build-your-own-header-save-%24300-bucks-15656/ |
wow!
[QUOTE=GTOMIKE;344610]
(Post 344388)
Yes stock manifold is very restictive take a look here. https://www.chevyhhr.net/forums/showthread.php?t=15656 |
[QUOTE=catdaddy137;344635]
(Post 344610)
i wonder why they made it like that?with those big humps? i bet would help just to take down the humps , just so they don't stick out. thanks for the thread. this doesn't mean that my 08 2.4 has aluminum exhaust manifold? Lazy GM just left it there in 07 when they reloacated it to the down pipe.Too get any serious gains in flow you would have too do it the same as I did. |
Will pacesetter headers part #72C-1279 work for 2006 2.2Ls hhr?
We don't have headers, we have a header. I realize it's common slang to use the plural form, but I've caught hell for it at meets and such. Thought I'd save you from the same.
