how to turbo
Welcome aboard gmoney!
Well I'm not too sure about a SAAB turbo being a bolt up job, but you can Turbocharge a 2.2L Ecotec engine if your patience and pockets run deep.
Give these threads a read....
https://www.chevyhhr.net/forums/2-2l...-not-ss-31623/
https://www.chevyhhr.net/forums/2-2l...evy-hhr-39112/
check with cjkrause, I believe he's done it with a 2.2L and a 2.4L. Or was that supercharging not turbocharging?
Probably would fit on the motor. After all the bolt holes seem to all be the same. But..... what about the ECM, BCM and the hood?
ZZP also has a 2.2/2.4 Turbo and Supercharger kit. Comes with everything you need. Install, get it tuned, and you should be good to go!
Stage 2 2.2 Turbo Kit |Stage 3 2.4 Turbo Kit for Ecotec Engines
TurboTechRacing
2.0L Performance Tech
0
Oct 28, 2009 09:03 PM
