No cold idle
Old Dec 6, 2024 | 08:39 AM
  #41
Tweetip10's Avatar
I put another new battery that I had from my motorhome. It made no difference.
Old Dec 6, 2024 | 08:54 AM
  #42
If it is misfiring there is a code.
Old Dec 6, 2024 | 09:14 AM
  #43
Tweetip10's Avatar
No code or ce light showing
Old Dec 6, 2024 | 09:18 AM
  #44
You stated in your 1st post that your code reader showed no codes. Then you said you went to AutoZone and they found codes.
So. Have you gone back to AutoZone to recheck for codes ?
Old Dec 6, 2024 | 09:38 AM
  #45
Then stop saying misfire, rough idle is not the same thing.
Old Dec 6, 2024 | 10:02 AM
  #46
Tweetip10's Avatar
Before it starts running smoothly, the engine will stumble like one cylinder is not firing. I call that a misfire and have for over 60 years! It is a “rough” idle when you first start the engine but seems to smooth out progressively as the engine warms.
Old Dec 6, 2024 | 10:26 AM
  #47
The computer would sense a misfirer. That is when a full ignition does not take place in a cylinder and raw gasoline is exhausted.
Old Dec 6, 2024 | 12:33 PM
  #48
Tweetip10's Avatar
I didn’t know the computer would pick that up.
Old Dec 6, 2024 | 07:45 PM
  #49
PulpFriction's Avatar
How old is the new battery that you had from the motor home? Any chance it spent time in a cold place in a discarged state?
You need to scan for codes again. Be sure to write down all the codes.
Old Dec 6, 2024 | 08:30 PM
  #50
Pending codes can cause problems.
SafetyDave
Sep 13, 2024 09:32 AM
Homer1230
Sep 29, 2022 07:45 AM
skysailor
Sep 7, 2021 05:57 PM
1bikenut
May 11, 2020 07:31 PM
daferris
Oct 3, 2015 12:44 AM
