No tach
No tach
Okay I haven’t done any checking yet but I finally finished the engine swap in the HHR I do have a check engine light I will research after the scanner charges but I don’t have a tach reading it’s on zero and it’s shifting into reverse and drive kinda hard. Any ideas?
update p0036 powertrain h02s heater control circuit bank 1 sensor 2
and p0335 crank position sensor
please advise?
please advise?
I did a search and couldn’t find a relearn on the site is there a topic on this?
I will I’ll have to inspect the o2 sensor after work tomorrow it was fine 7 months ago before this ordeal but who knows I may have knicked a wire or something. Or went bad from having the engine out for a month as it poured rain and what not. I did the motor on the street due to no garage so it sat a while
If you need a tachometer, maybe OBD2 scanner will help you?
I bought on Aliexpress one of those that can be connected to a smartphone via bluetooth (price $ 5). It has the function of a tachometer, and this is a fairly accurate tachometer at first glance.
