P0171 lean bank 1
Old Sep 8, 2016 | 04:24 PM
From post #1
i did this test: " Started the engine, unplug the sensor and drive it" the rough driving and pulling dissapeared, actually drove nicely
Now the CEL comes on with 6 DTC codes when you disconnect it!?
That is what I mean.
BTW, that test would be positive if unplugging it made NO difference in drivability.
Have you bothered to check the other things that were suggested? The flex pipe and EVAP purge valve being the common causes.
Just because the CEL is not on NOW does not mean there is no pending code.
Old May 6, 2022 | 08:46 PM
Bobbyong3's Avatar
Originally Posted by Tinky
Thats a good information to know !
I have questions that may be easier for you guys to answer:
1. The only problem now is to start the car... it may take 4 or 5 tries. OnCE it starts, it runs fine. No hesitation, no rough idle, no pulling. If it was a bad fuel pump, shouldnt i have problems also while driving???
Where would you start checking for the problem ???
I had this problem and after trying all sorts of fixes, turn out that it was a short in the crankshaft position sensor wires. After replacing the sensor and repairing the wire, it cranks with no problem. The sensor is located on the driver's side front of the block beside the oil filter. Its bolted into the block by one nut. A little difficult to maneuver the ratchet but I managed. Hope this helps.
Old May 7, 2022 | 07:28 AM
greg8453's Avatar
Since this post is more than 6 years old I doubt they are having this issue still.
Old May 7, 2022 | 07:43 AM
But, a fix I have not heard of before.
Old May 7, 2022 | 08:00 AM
Good information!
BDR1973
Apr 20, 2016 08:04 AM
donbrew
Nov 28, 2012 11:31 PM
Mrs.Clay
Sep 5, 2012 12:10 AM
Jfidelh
May 30, 2012 05:27 PM
