Reworked my Cold air intake
So I reworked my Air intake today and added a Maf sensor housing from spectre Performance, Looking at the results on my OBDII reader chart on my Iphone it seems to be bringing up the midrange and top end performance a little, (I believe) Next will be to clean the engine bay and maybe give the valve cover a polish.
I also removed the front shroud of the top of the rad because it was blocking the inlet alittle and see if that helps, I didnt wanna cut https://www.chevyhhr.net/gallery/fil.../5/intake2.jpg https://www.chevyhhr.net/gallery/fil...1/5/intake.jpg |
I cleaned the engine bay and polished up the cam cover a little
https://www.chevyhhr.net/gallery/fil...5/ecotech1.jpg |
Nice work!
Any noticeable gains in performance? And what did it cost you all said and done?
Where can you get that setup ? how much does it cost? thank you
The most important thing is the width of the MAF sensor pipe internally I used a kit for the maf sensor and I bought the rest of the tubing etc, $35 canadian free shipping the filter and pipe and connectors were from ebay another $45 canadian.
https://www.chevyhhr.net/gallery/fil.../5/spectre.jpg The internal plastic sleeve comes with three reducers on my car I used the 2.5" and swapped in my MAF sensor from my stock airbox using the appropriate adaptor. I've installed it and looked at my # with Iphone and Dash Command for what its worth, and it induction noise is up mid RPM and upper Rpm not any major HP increase, but it seems to rev alittle faster quicker better throttle responce, but im sure headers and a pipe will help too as I get the cash and time.:) No Codes Thrown running Good https://www.chevyhhr.net/gallery/fil...5/ecotech1.jpg |
Nice and it looks like it would readily flip over to the passenger side to allow room to change the oil filter
LOL I didnt think of that
mine is in the way, so I did notice that I hope that saves a mess when you change the oil filter!!
what is the part number for spectra? i want to get the right one...;)
| All times are GMT -5. The time now is 11:05 PM. |
