Rough Idle and car dies
P0315 means NO DATA for the crankshaft sensor variation. That comes from either a brand new ECM or one that has been erased. Oddly, there is no code for incorrect data.
Those other codes mean that the memory is screwed up in the ECM. A wild guess is that somebody let the positive battery cable touch the ECM housing, that happens frequently enough that there is a TSB about it.
The ECM codes or the crank sensor code ?
Don't know the order of the codes that were on the scanner.
Also Dark Knight just answered me on his thread about the used engine/crank sensor thing.
The engine runs and he has no crank sensor fault.
So no need for calibration when installing the correct used engine with a correctly working ECM that came with the car.
The ECM most likely will fix the other codes but not the crank sensor. And I say "most" with fingers crossed.
This is how it's done.
bad03xtreme
May 7, 2012 02:38 PM
