Single Cyclinder Misfire - intake valve spring - Page 3 - Chevy HHR Network
Reply
Thread Tools Search this Thread
Old 02-12-2018, 02:59 PM   #21
Technical Moderator
Okay, as I read your description, you did NOT remove the spark plugs?
The point was to get the SeaFoam onto the rings in force. I guess I should have been more precise I.E.: remove the plugs, then pour SeaFoam into the spark plug hole attempting to saturate the piston rings.
donbrew is online now   Reply With Quote
Old 02-12-2018, 08:25 PM   #22
After one day's driving, the P0303 was still reported when in low speed, especially during idling. Other than swapping and/or rebuilding the engine, is there any cheap way that I could try?
net_manager is offline   Reply With Quote
Old 02-12-2018, 08:29 PM   #23
Yes, I did remove all the 4 spark plugs first and added the seafoam into the 4 wells. I could see the seafoam covering the piston top (black). When I checked in the middle night, the seafoam was still covering the tops. After the whole night, all seafoam were soaked.
Old 02-13-2018, 09:28 AM   #24
I put the seafoam to the #3 well again last night. I could feel the engine run smoother than before. But in terms of the misfire P0303, nothing changed.
Old 02-13-2018, 09:52 AM   #25
Technical Moderator
Do the compression again just for kicks. It was a long shot.
Your terminology is what is confusing me. The depression in the valve cover that the plugs go down is a well; the area that the piston lives is a cylinder; to me anyway.
Old 02-13-2018, 10:36 AM   #26
So are you putting the Seafoam in the spark plug we’ll with the plug installed or down into the combustion chamber with the spark plug removed, just to verify
Oldblue is offline   Reply With Quote
Old 02-13-2018, 09:53 PM   #27
Sorry for confusing you with the wrong terms. My bad. Here is the process I did:
1) Removed all the spark plugs
2) Compression test
3) Put the Seaform into the spark plug holes, it went all the way down where I could see some carbons at the "bottom" of the hole. I stopped until the Seafoam fluid covered the bottom.
4) Waited for the whole night, rechecked each spark plug hole and didn't see any Seafoam fluid.
Old 02-13-2018, 09:59 PM   #28
I retested the compression again. One or two strokes brought the pressure measurement of #1, 2 and 4 to 180 psi. Four strokes brought it up to 210 psi. For the #3, One or two strokes brought the pressure measurement to 115 psi. Four strokes - 125 psi.
I added engine oil to #3 again. Then four strokes brought it up to 150 psi. No big jump as before. But it is still much lower than other three.
Old 02-13-2018, 10:14 PM   #29
I am wondering if this could be some carbon deposits on the intake valve of #3. I noticed my throttle body and even the intake air pipe connecting to the throttle body had a oil/fuel like black layer. Is it possible the intake valve of #3 couldn't seal the cylinder well due to the deposit on it?
Old 02-13-2018, 10:21 PM   #30
Over 200 PSI, if your tester is accurate, might indicate heavy carbon deposits in the combustion chamber. I mean a lot, it might take many, many seafoam treatments to clean it up.
I would try a different tester, auto parts stores have them in their loaner program.
But, yes there does seem to be a problem with #3 that the seafoam might be able to help with.
RJ_RS_SS_350 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Stock SS Downpipe/Cat, AEM Dry-Flow Intake, HHR Single Gauge A-Pillar, Turbo Pipe jmm121783 Inactive Classified Ads 8 11-12-2015 10:21 AM
HOW TO: bypass valve spring replacement badassbowtie "How To" Tutorial Library 3 11-23-2012 05:55 PM
Single Lake Pipes Pictures? SindyDix Appearance/Modifications Discussions 11 04-29-2006 12:11 AM
Single LED light BIGJP Audio and Video 17 03-08-2006 04:18 PM
Tags
fuel open loop, intake valve spring, p0303 misfire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2017 Internet Brands, Inc. All rights reserved.
