Transmission on 2.2 LT
You know, I have questioned that a few times. I was driving yesterday, with the A/C on and it seemed to get sluggish for a moment. Gave it a little more gas and it perked right up. Don't know if it was tranny, fuel, or I was dreaming. I'll have to keep an eye on it.
just drove it
a/c just about always on in texas
initial findings, more to come
2.2 auto here
Regular driving
2nd- 3600
3rd- 3600
4th- 3600
foot in it all the way
2nd- 6300 to 6500
3rd- 6300 to 6500
4th- had to slow down cause i was in a 40 zone and already at 75 and hadnt shifted yet. i am going to see if they have a new blue and take pics and will tell you about 4th on the freeway
I gear
normal driving
2nd- 4300
3rd- 4300
4th- in I gear you do not shift to 4th. all shifts are hard and a lil more aggressive. down shifts are harder and more aggressive and rarely get below 2600
foot in it
2nd- 6300 to 6500
3rd- 6300 to 6500
same as regular w one exception. the shifts are harder and i will advise when i get back what the drop to rpms was while shifting in both I and D. i want to see what the drop is to when it changes
2.2 auto here
Regular driving
2nd- 3600
3rd- 3600
4th- 3600
2nd- 6300 to 6500
3rd- 6300 to 6500
I gear
normal driving
2nd- 4300
3rd- 4300
foot in it
2nd- 6300 to 6500
3rd- 6300 to 6500
Originally Posted by DJ Koz
Even without the AC it seems like its still struggling. I never use I gear. What is it exactly? Does it screw up the tranny?
I haven't had any problems with my 2.2L 5spd at all. It runs great and has tons of power. Can even chirp the tires between gears. I'm sure the CGS and my lead foot testing it out had something to do with that.
using I gear hurts nothing just only uses the first 3 gears and will not get as good a gas mileage but performance is better. keeps you in the rpm zone.
i never seem to have this strugglilng problem
no imperial blue so they must have sold it over the weekend or it isnt there.
now to shifting on the auto tranny
Regular driving
2nd- 3600- dropped to 2700 to 2800
3rd- 3600- dropped to 2700 to 2800
4th- 3600- dropped to 2500 then real short after to 2200 then to around 1800
2nd- 6300 to 6500- dropped to 4200
3rd- 6300 to 6500- dropped to 4200
4th- - dropped to 2800 then to lower depending on speed. i was doing around 70 to 80 so it stayed there
regular rpms in 4th
70- 2600
75- 2700
80- 28 to 2850
I gear
normal driving
2nd- 4300- dropped to 2700 to 2800
3rd- 4300- dropped to 2700 to 2800
4th- no 4th in I gear
foot in it
2nd- 6300 to 6500- dropped to 4200 to 4300
3rd- 6300 to 6500- dropped to 4200 to 4300
4th- no 4th
i forgot to get cruising speeds in I gear at 70 to 80
i know I see it around 3600 to 3800 cause i use I gear alot
Regular driving
regular rpms in 4th
70- 2600
75- 2700
80- 28 to 2850
I gear
normal driving
foot in it
4th- no 4th
