Turbocharging Hhr 2.2L
Old May 1, 2020 | 10:20 AM
  #31
OshawaHHRss's Avatar
WOT box claims to provide NLS and launch control, the SS already has both. How is their product different? Do you have experience with the WOT box?
I'm going to have to pay attention to my boost gauge while in launch control, see if it builds more than 2 or 3 psi.
electric NLS > Vacuum controlled NLS. I’ll take a video next time I’m out at my car on launch control, I could build 20psi on launch if I set it high enough. I’m starting it at 4k rpm and working my way up
Old May 1, 2020 | 10:23 AM
  #32
So this is assuming the OP installs the 2.0 LNF 5 speed and computers in his LS/LT.
Old May 1, 2020 | 10:45 AM
  #33
Originally Posted by OshawaHHRss
there aren’t extra sensors. Run the 2.2 harness and computer. No tcm (or delete it, I did). You tune with hptuners, intercooler and charge pipes would work on a base model with the ss manifolds. You could use 80lb injectors and you’d have lots of fuel.
TMAP? Wide band O2 sensor. Where is 80Lb fuel pressure coming from, stock pressure is well below that.
Right forgot the manual trans doesn't need TCM.
So basically you are agreeing "cheaper and easier to buy an SS". If you want a 5 speed find a Saab trany and junkyard shift mechanism.
Old May 1, 2020 | 10:46 AM
  #34
OP would be better off to not use the LNF and build the L61. I’ve seen L61’s make some good power. There wouldn’t be any problems with harnesses or computers then
Old May 1, 2020 | 12:01 PM
  #35
So L61 with the LNF head to handle the boost and provide the DI and the HPFP?
Donbrew
80# fuel per hour not PSI
https://fuelinjectorconnection.com/p...dance-injector
Old May 1, 2020 | 10:34 PM
  #36
80lb injectors lol. And maybe, for cost turboing a base model with a 5 speed isn’t a terrible idea though. Extra sensors aren’t an issue if you use the stock L61 harness and computer
Old May 1, 2020 | 10:38 PM
  #37
Donbrew
no just the L61 head. Just port injection. Although an LSJ head would be better if you had one available. Either are good with some porting, springs and cams. My tuner has a turbo 2.3 cobalt making more than 600whp.
gmoney
2.2L Performance Tech
Feb 2, 2015 09:14 AM
PhightinKris
2.4L Performance Tech
Sep 27, 2014 06:54 PM
hhr_2009
Mar 1, 2011 09:12 AM
sarroj
Apr 13, 2010 10:34 AM
stangable
May 4, 2008 01:24 PM
