Won't start
Old Oct 4, 2019 | 05:30 PM
Since I 'm not exactly sure of the meaning of "timing chain tensioner froze up l drove home the car ran fine" means I am guessing that you did not get a new one to install the new chain. They usually come in the chain kit and are rather difficult to reset for use after you take them out.
I am not sure what Oldblue is thinking. If the key is at 12:00 AND all 3 of the marked links line up with the "arrows" it has to be timed right.
We have had a few instances lately of broken rockers. I don't know how that happens.
So now that is given; are we at does crank doesn't start?
Old Oct 4, 2019 | 05:36 PM
I think 180 degrees out. but I’m thinking none VVT, from an issue with a friends 2006 2.2 non VVT.
You say cams 10 and 2 but are the chain links lined up? Are you sure the triangle is at 10 on the exhaust and the diamond on the intake.
Have a close look at post # 10 in this thread
https://www.chevyhhr.net/forums/main...oke-tdc-58437/
Old Oct 4, 2019 | 06:17 PM
charliehines's Avatar
Yes I replaaced the timing chain guides sprockets and the tenisoner as well as the balance chain guides everything was replaced car cranks but wo't start. yes I drove the car home it was running fine
Old Oct 4, 2019 | 07:09 PM
If you don't even want to perform a free and easy compression test, I'm not sure that we can help you. Gotta start with the basics.
Old Oct 5, 2019 | 09:04 AM
I plan on doing a compression test today I never said I didn't won't to I don't know where that came from I will send the results later
Old Oct 5, 2019 | 09:07 AM
  #26
I'm positive the timing is the marks on the Chain align with the marks on the cams and cranks
Old Oct 5, 2019 | 09:15 AM
  #27
If you mean 360 on the crank, no such thing, not possible.
Thnaks my thoughts as well
Old Oct 5, 2019 | 09:28 AM
  #28
We have had a few instances lately of broken rockers. I don't know how that happens. So now that is given; are we at does crank doesn't start?
you are correct Don all timing chain guides tensioner and sprockets everything was replaced and set properly
Old Oct 5, 2019 | 09:33 AM
  #29
Maybe the pistons are broken, from contact with the valves. Have you performed a compression test?
I will do this today
Old Oct 5, 2019 | 09:57 AM
  #30
Well, you made 9 more posts after the suggestion without even acknowledging it.
Rocker arms don't just get tired and break. The camshaft lobes come up and push on the valves. If the valves cannot make the full stroke, things bend and break. I say this for future readers of this thread, it sounds like you already know this.
