ZZP on 2.2???
ZZP on 2.2???
Has anyone used the ZZP downpipe as a replacement on a 2.2. I've got a 2007 with the flex pipe exhaust leak problem, out of the 8/80 warranty and seeking a good fix. Any suggestions? Any details you can provide will be appreciated.
Thanks,
Thanks,
I put it on my 2.4l a while back. It should work for the 2.2. Quality is really good and the 3" dp never threw a cel with the high flow cat. Though if you appreciate a quiet ride you won't like the extra noise from the downpipe. I definitely noticed more cabin noise with the ZZP pipe, but it is performance oriented.
