Alcohol Level
Old Apr 16, 2015 | 08:07 AM
DrLoch's Avatar
Sounds like you need to use a data logger to see what is really going on.
Old Apr 16, 2015 | 08:21 AM
Been data logging for 18 months now.
Old Apr 16, 2015 | 09:52 AM
Blue_SS's Avatar
Interesting. Were both readings in closed-loop conditions? I would think even if the later one was not, that the system would revert back to the earlier one that was...
I know. Kind of grasping at straws here.
Old Apr 16, 2015 | 11:55 AM
DrLoch's Avatar
Have you seen the change in the post O2 when it threw the code?
Old Apr 16, 2015 | 06:30 PM
Closed loop, for the purposes of this particular discussion, the alcohol % is what puzzles me.
FWIW, what "they" say about the waves of the O2 sensors matching is what throws a P0420 is wrong. It is actually the equation:
Where:
1 = post cat response time - pre cat response time
2 = best failing OSC value from the calibration table (based on temp and exhaust flow)
3 = worst passing OSC value (based on temp and gas flow)
(1-2)/(3-2) = Normalized ratio
a Normalized ratio of 1 is perfect, a Normalized ratio of 0 is no cat at all.
The passing low Normalized ratio is either .35 or .50 depending on the alcohol content of the fuel.
OSC means Oxygen Storage Capacity.
This monitor is run after a certain drive cycle is run through, at idle, with the trans (auto) in drive. The A/F is forced lean then rich to obtain the response times.
Maybe I should cut n paste this into another thread sometime? The documentation for this can be found by following the link in my sig; https://www.chevyhhr.net/forums/how-...e-light-52828/
Old Apr 17, 2015 | 10:01 AM
  #26
DrLoch's Avatar
I agree, should start another thread with this information.
urbexHHR
Maintenance and Upkeep
66
Dec 30, 2016 09:31 AM
gto65lvr
13
Jul 30, 2011 05:40 PM
REDHHRSS
Jun 3, 2009 09:24 PM
ecl
7
Mar 4, 2009 09:42 AM
