Chevy HHR Network
-   2.4L Performance Tech (https://www.chevyhhr.net/forums/2-4l-performance-tech-14/)
-   -   Can I run 1/2 ethanol 1/2 normal gas in my 06? (https://www.chevyhhr.net/forums/2-4l-performance-tech-14/can-i-run-1-2-ethanol-1-2-normal-gas-my-06-a-15440/)
Graunkem May 30, 2008 01:38 PM
Has anyone done this? I saw an article discussing this in the local paper. If I can save a couple bucks a fill up I'd like to.
GDZHHR May 30, 2008 01:50 PM
No. The HHR fuel system is not set up to tolerate more that the 10% some states, like Missouri, require.
I guess, the real answer is yes. But why would you want to? Not any cheaper, less power, and less mpgs.
EcoBoost May 30, 2008 02:34 PM
You'd also run dangerously lean. Ethanol's ideal Air-Fuel ratio is much richer than gasoline's.
bigdog9586 May 30, 2008 02:43 PM
My dealer and I were talking about the HHR being able to use E85 next year. He says that with the vehicles out there now that the E85 has to be at least 40 cents less than nolead just to break even as far as fuel mileage.
ChevyMgr May 30, 2008 02:55 PM
Don't do it!
Your MPG drops 30% so if the cost is not more then 30% less for ethanol, then it's a bad buy.
Example:
Gasoline = $4.00 per gallon
Ethanol needs to be less then $ $2.80 per gallon
Graunkem May 30, 2008 06:02 PM
This is exactly what I was looking for. Opinions on ethanol in the car. I didnt think it was a good idea, but wanted to see what others thought.
The article was singing it's praises, so I needed to hear the other side.
EcoBoost May 30, 2008 06:42 PM
Not to mention all the corn on the cob I can't have if you fill up on ethanol!
courthousedeb May 31, 2008 07:14 AM
:laughabov :rof: :lol: :laughabov
