Chevy HHR 2010 2.4 litre starts but dies immediately
Old Apr 6, 2023 | 04:34 PM
None of those codes point to fuel pump or spark plugs. P0113, Is the MAF sensor plugged in? The other three have the vent valve in common.
Are these codes historic, pending, or current? (Status)
Are these from a recent read, or from before work was done?
Old Apr 6, 2023 | 04:43 PM
Nervesshotmamaneedsadrink's Avatar
​​​​​​MAF has been changed twice and it's definitely plugged in
Old Apr 6, 2023 | 07:23 PM
https://www.obd-codes.com/p0496 Is for the purge valve. You can’t blow air through it? In either direction?
https://www.obd-codes.com/p0446
Yes EVAP vent valve
https://www.obd-codes.com/p0113
The device is the MAF sensor
https://www.obd-codes.com/p0442
Faulty vent valve or purge valve
All can be related to loose wires, chaffed wires near the purge valve bracket under the hood.
Old Apr 6, 2023 | 08:34 PM
The IAT and the EVAP purge valve are on the same fuse.
I would be looking for a rusty EVAP tube. And a wire ti the MAF. P0113 could be caused by 2 wires making contact. , it indicates a short circuit.
K246dea
Apr 28, 2023 09:52 AM
jjohns10
Oct 25, 2021 03:37 PM
DangerBoy
Jul 20, 2017 07:24 AM
