Chevy HHR Network
-   2.4L Performance Tech (https://www.chevyhhr.net/forums/2-4l-performance-tech-14/)
-   -   Deceleration Fuel Cut off (https://www.chevyhhr.net/forums/2-4l-performance-tech-14/deceleration-fuel-cut-off-16957/)
American Misfit Jul 21, 2008 09:06 PM
Does anybody know if the ECU shuts the fuel injectors off when decelerating, especially when left in gear?
1Panel2NV Jul 21, 2008 10:25 PM
This has been talked about on css.net, and most people agree that fuel cutoff only occurs while in gear.
Take that hypermiling thread lol
Snoopy Jul 21, 2008 10:28 PM
Without thinking this out entirely....
Wouldn't the engine stall if the fuel injectors stopped the fuel from injecting....nothing to combust.:confused:
Seems to me, if you were decelerating by removing your foot from the gas pedal while going down a long hill, for instance, the engine would stall...no steering, no brakes...
1Panel2NV Jul 21, 2008 10:31 PM
Manual transmission...
Snoopy Jul 21, 2008 10:34 PM
Does it matter???
xzombiex66 Jul 21, 2008 10:50 PM
Yea i mean for your engine to operate it needs gas, how would shutting the injectors down keep the engine running? I'm confused:confused:
mistermike Jul 22, 2008 08:01 AM
In gear, the momentum of the vehicle keeps the motor turning.
JoeR Jul 22, 2008 08:06 AM
DCFO does cut fuel to the injectors, on both auto and manual trans. There are a bunch of parameters and tables that control how it works. The only differences between the auto and manual calibrations are related to speed in gear due to ratio differences. Otherwise the same.
In a vary basic sense, it will work above certain speeds and RPMs. It will disable below certain thresholds and that is why the engine won't stall.
ChevyMgr Jul 22, 2008 09:03 AM
Are we talking about HHRs here? Fuel never cuts off when the engine is running and if it does the engine stops running, so there is a problem. Only a hybrid shuts off all fuel injectors and vehicles with "Active Fuel Management", such as Tahoes and Suburbans, cutoff 4 of the 8 cylinders at times.
1Panel2NV Jul 22, 2008 03:40 PM
I was hoping someone more knowledgeable would step in JoeR, hehe. I thought it was only for manual transmissions though.
This information was discovered with hptuners wasn't it?
