e3 Spark plugs
Old Aug 26, 2013 | 08:46 PM
ppaul's Avatar
which delco?
I have a '09 witha V engine code (2.4), after reading the threads, I will get delco iridium or platium plugs, the car had 86K on it and as far as I know these are the original plugs. also should I think about replacing the wires since I'll have the air cleaner off then. what plugs do you find better? any info will hepl. thanks
Old Aug 27, 2013 | 01:10 AM
best plugs - as Originally Posted by ChevyMgr back in 2010: "12625058 a/c delco spark plug (iridium)"
Fyi: there are no spark plug wires on the 2.4.
Old Aug 27, 2013 | 09:57 AM
ppaul's Avatar
re: which delco
thanks for the information. this makes the first car I have had that did not have plug wires
Old Aug 27, 2013 | 11:04 AM
check out - https://www.chevyhhr.net/forums/maintenance-upkeep-50/checking-replacing-air-filter-10757/ which goes through the process of removing the Air filter housing which you will need to do to get at the plugs. One of the pictures partway down the first post in the thread shows the valve cover and the 4 coils which will have to be removed to get at the plugs. Not a difficult job at all. Good luck.
Old Aug 27, 2013 | 12:39 PM
LowHHR's Avatar
I use to up sale people to "better" spark plugs for their older Chevy's. Two weeks later they would return them for AC Delco's. My motto was Ford= Motorcraft, Chevy=AC, Mopar=Champion
jeffros hhr
Maintenance and Upkeep
Dec 29, 2014 08:24 PM
jay loukakis
18
Dec 21, 2013 12:00 PM
ChevyGuySS
2.0L Performance Tech
17
Sep 5, 2012 07:50 AM
Red5spdSS
35
Apr 3, 2011 08:39 PM
hvrod
2.4L Performance Tech
Jan 7, 2006 09:11 PM
