ECM 3 ports or 2 ports?
1 Attachment(s)
So! A riddle:
A 2.4lt ECM has 3 ports, and a 2.2lt has ECM has 2 ports. What's the extra small blue port for and do I need it? Could I use this 2.2lt ECM on my 2007 HHR 2.4lt engine? Thanks! |
I don't know exactly what the connector is for, but there is obviously another harness that plugs in.
I wouldn't think that a different part number could work. |
Guessing it has to do with the 2.4 having actuator solenoids and the 2.2 doesn't ?
Like I stated. Just taking a wild guess. |
1 Attachment(s)
The ECM for the 2007 2.4L seems to be unique to that year.
2008 they both use the same part 2 connectors.ACDELCO 216140 {#12597125, 12612397} 2009 both use the same ECM, the one with 2 connectors. 2009 has VVT. They are completely different for both in 2006. There are several updated part numbers. |
Those are the J connectors for the ECM, no you cant use a 2 connector ECM on a 3 connector car.
Originally Posted by 1970judge
(Post 807047)
I think the question was the other way around. |
The J connectors consist of the ECM pin numbers for the harness. Either way around it wont work. You must replace it with your ECM designated for your car.
