Harmonic Balancer bad = New engine?
Old Aug 7, 2022 | 10:11 PM
greg8453's Avatar
There's more to this story. What I think happened is the engine was losing a bearing or two and it may have wiped the front out which caused the balancer to go ****eyed.
Old Aug 9, 2022 | 05:35 PM
Blue_SS's Avatar
Harmonic balancer failure by itself is fully recoverable, with a replacement and maybe a belt. If you got some crank walk or something as the real root cause, then your guy is probably right. Doing major repairs on the bottom end might not make sense. You're doing the right things to ask some more questions.
Old Aug 15, 2022 | 08:37 AM
califphil's Avatar
See if it's possible to have someone weld a new balancer to the crankshaft snout. You have nothing to lose at this point and it might last for another 100,000 miles like that.
Old Aug 15, 2022 | 08:43 AM
This seems like a terrible idea. Why would you suggest this? How would you get it apart if engine work was needed?
Old Aug 15, 2022 | 09:17 AM
califphil's Avatar
Obviously it would not be able to be removed, but throwing away a 56,000 mile motor and spending $1000's of dollars when a few hundred dollar weld job might save it and then he could drive it until the timing chain needs replacement. It's just an option that the OP might not have thought of.
Old Aug 15, 2022 | 10:58 AM
I still think just a new balancer and crankshaft bolt should fix the problem, but photos are required to confirm
Arbius79
Maintenance and Upkeep
21
Aug 24, 2022 05:51 PM
Nazramoth
Feb 4, 2017 03:19 PM
SwaintaN
Mar 25, 2014 12:16 PM
moonsign
2.0L Performance Tech
39
Aug 31, 2010 07:53 PM
bradbutner
May 16, 2008 10:52 PM
