installing after market turbo
I am new to the hhr network but I have got my hhr to the very end of the turbo setup process. I have a t3/t4 with air to air intercooler. Made my own intake maf housing. Put #80 injectors and am currently running e85 but after all this work I'm now getting p0606 codes after sending my ecm and tcm into zzp for tuning. At first it was throwing lost comm with tcm after grounding it to frame its now stuck in limp mode with p0606.
https://cimg0.ibsrv.net/gimg/www.che...cdfda07b68.jpg Dark but this is my spray with tractor / farm equipment paint. Satin black https://cimg1.ibsrv.net/gimg/www.che...93f11c5420.jpg Overlook the mess. Im not going to put much into looks untill i get functionality. |
Mostly like fuel starvation without a HPFP.
Get rid of the "farcebook ground"; it is dangerous and completely useless.
P0506 means that the ECM is not programmed or the connection to the throttle actuator is balky. My first guess is that you bent or pushed a pin or 2 in the ECM connector. Maybe ZZP messed the ECM up. Communication codes usually caused by wiring or fuses. |
Originally Posted by Oldblue
(Post 940874)
The 55 to 60 psi in tank pump won’t keep up. So perhaps a higher capacity electric fuel pump
https://walbrofuelpumps.com/255lph-w...pump.html.html |
You should be talking to ZZP.
Zzp
(Post 940890)
(Post 940889)
This says it's an internal fault in the ECM https://www.obd-codes.com/p0606
What's the significance of this 2 week period? Here are the 80 pound injectors on ZZP https://zzperformance.com/products/siemens-80-injectors You have the 2.4(LE5)? On that page ZZP says you need this https://zzperformance.com/products/b...ressure-system if you're making 12 psi or more boost. |
Ecm
(Post 940922)
