LE5 replacement for LE9
Old Jan 13, 2021 | 01:10 AM
nfuller20's Avatar
I got myself a 2009 HHR with a bad LE9. From what I could gather, the only differences between it and the LE5 are injectors and the ecm, and possibly the valve material. Is it possible then just to use the injectors/ecm on the bad motor and swap them over?
Old Jan 13, 2021 | 06:47 AM
They will fit, the camshafts are different, so you might consider swapping those also.
Old Jan 13, 2021 | 08:28 AM
And a new timing set.
Old Jan 13, 2021 | 04:53 PM
nfuller20's Avatar
Is the timing set different or is it just as a precaution?
Old Jan 13, 2021 | 07:08 PM
A precaution, the timing sets are the same, for the LE5 or LE9 , the Cloyes 9-4201SA doesn’t include the VVT actuators, the 9-4202S kit has the complete balance shaft chain kit guides and tensioner.
I highly recommend an upper front guide replacement bolt from Melling or Dorman, both work great.
This is a great link to check out, and instructions to assemble the chains
http://www.ddmworks.com/assets/image...uild%20Kit.pdf
Old Jan 14, 2021 | 09:39 PM
Scorangehhr
Sep 29, 2016 09:18 AM
thehappyfrog
2.4L Performance Tech
Jul 7, 2016 12:05 PM
2009HHROD
Jun 15, 2012 04:36 PM
gcsd3742
May 8, 2008 06:30 AM
Bowtie388SBC
May 24, 2006 06:32 PM
