MAF Problems
Old Feb 7, 2006 | 06:44 PM
  #41
en0oNmAI's Avatar
I will post pics in a new thread though if the system lets me. Hope my 2 cents has helped!
Old Apr 29, 2006 | 08:57 PM
  #42
fre2fall5's Avatar
airflow must travel through
if you move the maf you have to make sure the air flow is not missing or is being redirected as to not flow through the area inside the maf and flow over the hot wire. try turning the maf 180 deg.
Old Apr 29, 2006 | 10:49 PM
  #43
cj krause's Avatar
Originally Posted by en0oNmAI
I built a cold ait for my 2.2L hhr and had the exact same problem you are having. Appearantly the stock setup is hiding something becase the second you put everything right the light goes off (CEL). It's almost as if modifying the intake on the hhr is a no no and chevy wants it kept that way. I have found something that helped and stopped the engine light from going on but do not take ANY responsibility for anyone else doing this! I just bought a 2nd MAF housing and used it in conjunction with the rest of my tubing setup. No light, no burble, not stall. Works great but my routing doesnt hit throught the fender in the passenger side. I found I have more room dropping in between the lower rad. hose and the coils then into the driver fender! Sounds nice and I can touch the pipe after running hard and its cool to the touch. Not bad for southen AZ weather!
Jason
i would love to see the set up in pics and how u did it. i have been working on that too to get rid of all that black housing and hoses.
if you take pics can u email them or post them,, i would really like to see what you did.
Dharkons
Nov 29, 2017 04:42 AM
06chevyHHR
Jan 22, 2013 05:55 AM
SmootHHR
May 22, 2011 04:38 PM
HHR4JK
Apr 9, 2010 06:48 AM
SPPD
Jul 16, 2008 01:22 PM
