My 2.4 just began having a click
Old Dec 10, 2024 | 06:50 PM
My 2008 HHR 2.4 has just started having weird engine click when I turn key partially on. Then when I turn key off I get a click again.. 39699 miles on it..
Runs super, but this click sounds at top of engine, kinda in middle. Weird deal
Add on: only 1 click is heard when I turn key partially on.. And only 1 click when I turn it off..
Full of oil, etc..
Old Dec 10, 2024 | 07:30 PM
Maybe the EVAP purge valve.
Old Dec 10, 2024 | 07:33 PM
Would that throw a code ? This just started. No codes showing on dash
Old Dec 10, 2024 | 09:22 PM
It is a solenoid, just clicking would not set a code.
Maybe one of the relays in the fuse box?
Old Dec 10, 2024 | 09:42 PM
OK, sound is near valve cover.. Doesn't sound near fuse box, just very audible click
Old Dec 11, 2024 | 06:57 AM
Anyone ?
Old Dec 11, 2024 | 07:03 AM
Billy. How about a video ?
Old Dec 11, 2024 | 07:17 AM
Turn key on but don’t start engine and hear one click .
Possible the VVT solenoid or fuel injector , or evap purge valve.
do you hear the click when you turn the key to start your car?
Old Dec 11, 2024 | 07:22 AM
PulpFriction's Avatar
Remain alert, but don’t worry too much. Solenoids are electromechanical devices, and the mechical parts can vary and wear enough to cause changes in sound. Also, I can say from personal experience that one can become alarmed when one first notices a sound that has (probably) always been there.
Worry has an amplifying effect. Need a name for that.
Now I need to get in my 2011 and listen for noises. Will repot back. Maybe.
Old Dec 11, 2024 | 07:31 AM
FMG- Hard to do by myself...
Blue- Yes & when turning off as well. I hear
it before I start mine, I let fuel pump run, then start. Same when I shut off, 1 click
PulpFricton-
Pretty tuned in to sounds, this I believe is new
Sounds near throttle body or behind it..
