My 2.4 just began having a click
Old Dec 11, 2024 | 08:30 AM
PulpFriction's Avatar
One of my points was that a solenoid or relay can become louder, which may or may not be a sign of impending failure. Modern relays are mostly solid-state, I think, so I’d be looking at solenoids.
To find the source, with the aid of an assistant, you could try the old piece-of-hose-as-a-stethoscope trick.
Old Dec 11, 2024 | 08:59 AM
i have a stethoscope, just need assistant.. Maybe an eager body at parts store.. Thank You all..
Old Dec 11, 2024 | 09:30 AM
I tried to get mine to the same circumstance, no click , the fuel pump primes immediately.
Old Dec 11, 2024 | 12:36 PM
OK, Thanks, my fuel pumps immediately also,,,
Old Dec 11, 2024 | 04:58 PM
greg8453's Avatar
Just the main turning on.
Old Dec 12, 2024 | 10:05 AM
Yes, then turning off as well..
Old Dec 12, 2024 | 10:07 AM
possible VVT solenoids. ?
Old Dec 12, 2024 | 10:26 AM
Yes, but they usually cause the CEL to turn on and a code.
Old Dec 12, 2024 | 11:04 AM
Not if they’re functioning properly.
Old Dec 12, 2024 | 03:39 PM
But the VVT solenoids don’t click normally until oil pressure rises
