a new unusual noise...???
Old May 27, 2013 | 09:04 PM
dustin6119's Avatar
upon "pedal to the metal" I am hearing a "rattle" or "vibration" or even a "sucking" noise (<<<if its a vaccum line) it occurs only a full acceration...it does it at all RPM levels...doesn't matter what gear its in...by the way its an automatic and a 2.4 L...LS
the car does not stall,stammer or hesitate in any way has no loss of power and performs as always....not really to concerned about it other than I have never heard it before??? any ideas?....89,000 miles, oil changes on time and I run 93 octane all the time....
Old May 27, 2013 | 09:08 PM
flex pipe?
Old May 27, 2013 | 09:34 PM
dustin6119's Avatar
please explain??
Old May 27, 2013 | 10:44 PM
It's a flexible section of pipe between the exhaust manifold and the down pipe, it allows the engine to shift in its mounts without snapping the down pipe off.
Give this thread from badassbowtie a read....
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-repair-flex-pipe-31536/
Old May 28, 2013 | 11:22 AM
IgottaWoody's Avatar
Hmmm..sucking noise may actually be a blowing noise just starting......
Old May 31, 2013 | 04:40 PM
Lake Runner's Avatar
The problem I found with the flex pipe on my '08 2.4, was that the primary "cone" at the inlet of the flex pipe. This inner cone is thin and was cracked on the entire circumference. This allowed the cone to move about and not transfer exhaust gases directly to the exit side. I replaced the flex pipe with a different design that doesn't have this cone. I kept the old one to examine.
Old May 31, 2013 | 08:16 PM
Yep, that cone always breaks loose.
Old Jun 2, 2013 | 05:59 AM
dustin6119's Avatar
goning to be working on it TUE. I'll let you guys know what I find.....aand then I'm putting new complete struts on.....it could be the roads around here but that slight vibration in the steering wheel is driving me crazy !
Old Jun 2, 2013 | 10:36 AM
Now you mention a slight vibration in the steering wheel? Check the wheel hub/bearings.
Old Jun 2, 2013 | 11:48 AM
dustin6119's Avatar
front end alignment from the dealer,tires rotated and balanced,new rotors (NAPA) best they have....still has a vibration....the only thing currently "known" is the seals are leaking on the struts>> so I'm changing those TUE after I fix the flex pipe...also the hub bearings on the passenger side was relpaced last week.....so maybe still could be the ones on the drivers side but its making any noise yet??
