Performance high voltage ignition coils
Old May 1, 2020 | 02:30 PM
Blue_SS's Avatar
You are not wrong... But.....
A coil only dumps as much current as needed to cause spark. If any particular engine design (high comp, nitrous, extreme RPM, etc.) is functioning correctly with coil "A" adding hotter coil "B" will not increase performance. The amount of current dump will remain the same for both coils.
This guy has it right. And, with computers managing your timing and fuel trim, you aren't going to see a benefit.
Old May 1, 2020 | 03:22 PM
Cat Man HHR's Avatar
Isn't that waht I said?
Isn't that what said also ?
So we're both correct.
Let's move on to more challenging problems.
Old May 1, 2020 | 04:01 PM
Snoopy's Avatar
Don.....
Just a reminder, because you do know this...be careful with consolidated auto parts websites. They advertise WHAT FITS, not what is correct to OEM. Remember all the problems with shocks that fit the SS, but didn't meet the weight and pressure specs of the SS
Just went through that with replacement rear air shocks for an Aurora.
bad03xtreme
Nov 22, 2017 03:31 PM
bullittfan
2.4L Performance Tech
Jul 4, 2012 07:29 AM
ericm1a2
Jun 3, 2011 08:15 AM
racer-ray
Jun 27, 2010 08:01 AM
hogwild
Jun 7, 2008 11:07 PM
