Random cylinder 4 misfire
You could remove one VVT solenoid at a time and check the screen for debris, but those usually throw different codes. This is why it’s recommended to exchange the coil with a different cylinder see if the code changes to the new cylinder, same with injectors , when it’s intermittent like you say, it could be damaged wires or connectors, loose ground wire. There’s the coil connector and the injector connector to inspect.
you really don’t need to throw parts at it, just test and verify. Like exchange #4 spark plug with #2 cylinder
When you installed the crank sensor did you get the variation relearned? A wrong variation can cause P0300.
P030-0 does NOT mean "random misfire" or even anything like that. It means "something like a misfire is detected". It is detected by variations in RPM by the crank sensor, each crank sensor needs to be calibrated.
