The MAF is that bit that you must unplug to get the air cleaner off. Either it is not plugged in correctly, a wire is broken or it is broken.
Originally Posted by donbrew
(Post 826415)
Correct, and it usually sets a CEL
Thanks for the info, everyone
Thanks for the help, I will check it out Could a separation in the air intake hose cause a problem? Just discovered this |
If you mean the fuzzy pipe that goes to the fender; no.
If you mean the rubber pipe that goes to the carb; yes |
It is the one that goes to the fender...TG
1 Attachment(s)
The cold air intake tube you speak of , commonly called the woolly worm, is abut expensive but can be replaced by a 3 inch diameter piece of dryer hose, the metal style like this
Originally Posted by BethnPete
(Post 826396)
Just curious...what RPM should a 2008 2.4L be running at 55-60?
My 5speed is at 70mph at 3000rpm. 5th gear |
(Post 826402)
I can drive it at 55-60 running at 2500-3000 RPM
4th would be 2000 rpm at 60 mph using 215/50R17 tires |
