transmission swap
Old Jan 31, 2023 | 12:37 PM
Steve pugh's Avatar
transmission swap
I have a 2008 LT with the 2.4 and automatic transmission ( which I have to replace ) and I was wondering if a tranny from a 2.2L would work in my car? Also I've seen that some cobalt transmissions will work. Will someone give me advice and steer me in the right direction?
Old Jan 31, 2023 | 12:46 PM
The 2.2 and 2.4 had the same 4T45E automatic transmission, might be different gear ratios in different years, but close enough, even the SS models had that same transmission maybe some fortified parts in it.
be careful with the electric connector and the gear shift cable, and change the fluid and filter, replace the pan gasket with a GM gasket, the aftermarket rubber ones leak.
Tooldude
2.4L Performance Tech
Sep 2, 2019 12:33 AM
harvardman
2.0L Performance Tech
Nov 4, 2018 06:41 PM
RF2
Jan 12, 2014 08:36 PM
Justintime83
2.2L Performance Tech
Jan 11, 2011 08:47 PM
Tony_SS
Dec 19, 2009 07:59 PM
