Chevy HHR Network
-   2.4L Performance Tech (https://www.chevyhhr.net/forums/2-4l-performance-tech-14/)
-   -   TTR solid engine mount install (https://www.chevyhhr.net/forums/2-4l-performance-tech-14/ttr-solid-engine-mount-install-48999/)
bassbase Dec 25, 2013 03:30 PM
Question to all who have installed the TTR solid upper mount:
Do you have to support the engine during removal of the old mount or can you just unbolt the old and bolt in the new? Doesn't look like you have to support it but haven't seen any how-to's on it yet.
firemangeorge Dec 25, 2013 08:48 PM
I would say yes since the front of the engine would/should drop down a lttle when you remove the bolts.
When I installed mine, first thing I did was slide my small jack under there with a small piece of wood between the jack and oil pan.You should be able to turn the steering all the way to the right to get a jack under there. I jacked it up a little to take the pressure off of the mount and bolts.
Removed the washer reservior. Then I swapped out the mount. Easy job. Took about 15 minutes.
note: you should torque the mounting bolts to factory specs. ( can't recall the settings. Since I'm at work, sorry, can't look them up.)
bassbase Dec 25, 2013 08:57 PM
Thanks. Did you notice a difference in torque transfer to the wheels? I also heard it creates a bit more of a vibration feel because its so solid. True?
Ordering mine in a week or two along with the ZZP header.
firemangeorge Dec 25, 2013 09:43 PM
Yes. One thing it seemed to eliminate was the wheel hop I was getting when slightly breaking traction.
The vibration? Oh yeah. You'll notice it. Drove me crazy for a few months. I guess I'm just used to it now. Doesn't really bother me any more.
firemangeorge Dec 26, 2013 02:06 PM
Bolts: Engine Mount to Intermediate Bracket 65 N.m 48 lb ft
Nuts: Engine Mount to Midrail Nuts 100 N.m 74 lb ft
(Not quite sure about these nut torque specs. Seems awful high to me. But, the specs did come from the repair manual.)
TurboTechRacing Dec 26, 2013 02:25 PM
Our mounts come with color step by step instructions...
bassbase Dec 26, 2013 09:44 PM
Cool. Ordering here shortly.
843de Dec 27, 2013 01:31 AM
You'll find that TTR's instructions are very well written and thought out, more than a few manufacturers/vendors could learn from them.
TurboTechRacing Dec 30, 2013 06:49 PM
Thanks!
bassbase Jan 1, 2014 05:03 PM
Any sales coming up on them soon?
