Added fog light inserts and Dash Kit////PICs
Old Nov 5, 2007 | 11:23 AM
redrider's Avatar
Yes , have used rain-x on a 46 street rod pick-up that we used to have. It works very good
Old Nov 5, 2007 | 03:23 PM
gravett1's Avatar
Looks Great
Old Nov 5, 2007 | 04:25 PM
enri9267's Avatar
Did the chrome fog inserts, slide around the standard fog lights. If so, where did you get them. Thanks...!
Old Nov 5, 2007 | 09:38 PM
Kingfrog's Avatar
Originally Posted by an08HHR
I was looking at the pic of your medicine cabinet and didn't see any RAIN X, I find it works greats, rain (and snow) just seems to shed off the windshield without using your wipers. Note; clean the windshield very, very good before applying or else it leaves a smear. Any one else ever try this product? It is like $5 for 8oz . I tried RAIN BLOCK from Walmart but it isn't worth it. Hope you solved the lifting problem you had with some of the dash kit pieces. Looks good.
Actually I use the Zaino. Its a poly carb and does the same thing as Rain-X.
I use it on the bike shield too as there are no wipers and the rain sheets rather then beads.
Old Nov 6, 2007 | 11:52 PM
Daverb's Avatar
Looking good. Heres how mine looks.
Last edited by Daverb; Nov 6, 2007 at 11:56 PM. Reason: to fix 2nd pic, did not show
Old Nov 7, 2007 | 08:50 AM
Kingfrog's Avatar
YEah they do. You have to use alcohol to slide them in and get them lined up right. They stick VERY easily. I bent the lower insert trying to get it off after it stuck wrong.. Then you apply the trim around the lights. I got mine at the PT Show here in Myrtle Beach from HHR Boutique Think I paid around $69 or so.
Old Nov 7, 2007 | 08:52 AM
Kingfrog's Avatar
That looks great. I think I rushed mine. I have loose corners I had to glue and tape. The rings around the front speakers were a bear. I did find some better plastic adhesive kit at Autozone which when taped for a few hours is like a weld!
Old Nov 7, 2007 | 09:05 AM
enri9267's Avatar
Thank U...!! Just added another item to the X-mas list.
Old Nov 7, 2007 | 11:24 AM
GER42's Avatar
I've been using it for many years
Old Nov 7, 2007 | 09:29 PM
Daverb's Avatar
I did mine on a warm day, around 80. But like you, I had someproblems with the corners on a couple of areas, think I did't have enough of the activator or let it stand to long. So, like you I used some adhesive.
Rcflyboy
"How To" Tutorial Library
23
Aug 27, 2016 08:24 PM
jeff schaffer
Mods - Interior
Jul 3, 2015 11:41 PM
itschaboykenny
17
Jun 6, 2009 10:26 PM
TooTall
18
Jul 20, 2008 01:40 PM
