Chevy HHR Network
-   Appearance/Modifications Discussions (https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/)
-   -   Can I mount 2008 window switch unit to my 2009 (https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/can-i-mount-2008-window-switch-unit-my-2009-a-22216/)
UncleDannie Mar 2, 2009 10:55 PM
I have a 2009. The window controls were moved to the armrest, and now there is nothing on the lower center console unit. I wanted to install the plastic mount from a 2006-08 unit that housed the window controls to my 2009. I thought it would be a great place to add switches or LED lights for various other items to my 2009.
Question: Will this mod work? Is there enough space? And finally, what is the part number I need to look for? I have inserted a photo of my console.
https://www.chevyhhr.net/gallery/fil...HHRConsole.jpg
ecl Mar 2, 2009 11:31 PM
Yeah it should work just fine just pop out that piece and reinstall the other, as for the part # not sure.
masterchief1112 Mar 2, 2009 11:34 PM
i would try to find a wrecked hhr may be cheaper.
HillsdaleHHR Mar 2, 2009 11:37 PM
That is one thing I dislike about mine. The center piece storage container is just ugly!
UncleDannie Mar 3, 2009 12:08 AM
Thanks for the fast responses. I guess I'll try the wreck route and see if I can get one.
prod Mar 3, 2009 12:54 AM
LOL, there must be someone on here wanting to do a swap. I have read sooo many posts about wanting window controls on the doors.:lol:
masterchief1112 Mar 3, 2009 01:27 AM
you could do the swap but what about shen your passenger wants to put their window down. also i dont think he is trying to move them just wants to use the window button plate for something else if i read right.
fastsuv Mar 3, 2009 07:29 AM
The switch bezel for the 2006-2008 models lists at $41.67. GM Parts Direct has them for $24.70 (plus shipping).
The part # is 15883623
Steve
fastsuv Mar 3, 2009 07:32 AM
Also you will need the rubber liner that goes into the storage bin under the switches. It lists for $3.60.
Steve
prod Mar 3, 2009 12:18 PM
Reading the post again, I see what you mean.
But to use the GM switch panel, I think you would need to use the same switches too to make a good fit for the holes.
Perhaps the best thing would be to just add a flat panel over the bin and make your own holes according to what you want to put in there.
