Carbon Fiber applique
5 Attachment(s)
My wife thinks the interior of our HHR is dull, so I went looking for a way to upgrade inexpensively. I found 3M Di-Noc to be the solution as the custom fit appliques were expensive and the reviews were not all that great. I wrapped the Waterfall, and both front door handle/ bezels plus the darker "stripe" in the door panel that was really scratched up. Total cost: about $60 including replacing the window switch bezels because I thought black ones would look better than the gray in the car.
To do this, watch as many videos on YouTube as you can stand (search for Di-Noc and you'll find plenty. You can get the vinyl and the primer from Amazon. All of the other tools are described in the videos. I also built a "holder" for the door bezels (just a board that you can fasten the bezels to using screws in the mounting holes in the bottom of the cup) Attachment 18059 The Waterfall will require another person the help you hold the part while you stretch the vinyl over it. Passenger Door Attachment 18060 Driver's Door Attachment 18062 Waterfall Attachment 18061 Tips: Use the hair dryer/ heat gun liberally and often. Make sure switches fit in their holes and operate before re-assembly ( a real problem with the hazard warning switch. This is not that hard to do but take your time. If you mess up, you've only trashed a small piece of vinyl, the part should be undamaged, try again. I found this better than spending $250 on the pre cut parts, especially since I wouldnt use all of the parts anyway. |
Nice work , very cool!
Wow! That looks fantastic, great job! :twothumbs::twothumbs:
I am really liking what you did!
Nice work! |
Looks great
I liked it, too.
modestly and with dignity |
Very nice work. I'm not really a fan of carbon fiber, but I'd be happy showing that off! Takes a lot of time to do it right.
-hats off to you sir |
Really Nice work
I've done my waterfall...but now you have me thinking about those other parts!
https://www.chevyhhr.net/gallery/fil...0/5/7/dash.jpg |
Originally Posted by Putter
(Post 795150)
