Custom Headlights w/ LED Angel Eyes & LED Audi DRL
Old 10-17-2013, 11:58 PM
  #41
fcazares's Avatar
Originally Posted by Double0
New pics as of 16 July 2010
I am also re-running for feature of the Month of August!
How did it cost you? is it hard to do it and how long did it took you to finish them?
fcazares is offline
Old 03-24-2019, 07:06 AM
  #42
karaokedave's Avatar
where can I get a set of these???
karaokedave is offline
Old 03-24-2019, 07:14 AM
  #43
Hard to say because the thread is from 9 years ago.
firemangeorge is offline
Old 03-24-2019, 08:09 AM
  #44
Technical Moderator
See post #13.
donbrew is offline
Old 03-24-2019, 04:57 PM
  #45
Cat Man HHR's Avatar
Get your hands dirty. Your going to have to build your own.
Cat Man HHR is offline
Old 03-25-2019, 09:35 AM
  #46
solman98's Avatar
You have to make them.
solman98 is offline
Old 10-27-2019, 09:16 PM
  #47
Tshane3000's Avatar
Sun roof in quotes??
I figured it out this weekend. I ran a wire through the fire wall and got switched power from my "sun roof". The DRL only come on the key is in.
Does that mean there is NO sun roof, only a space for the fuse (with wiring ran to *nothing* on top or no??), but wires run from fuse box to battery?
I have 2010 LS.
I want separate switch from main headlamps for LED angel or halo around main lights plus "eyebrow" or "eye underliner" w same color temperature as LEDs--ice white, maybe 5000°K, not existing/standard halogen at 3500° or 4000° K.
And if I want to concurrently run, with those added LEDs, new ice white running lights at the bottom in the existing holes plugged with cheap plastic fill pieces, what do I need to install?
Do I need to change out that electronic lighting control component (begins with "B", I can't go back while writing to see the acronym) for a HHR LT? Could I get one at a decent price (any estimates?) from a junkyard? Is it easy to install without crazy and expensive electronic tools and other modifications?
I also have an old KC highlights kit with 2 incandescent lights. Not sure if those connect directly to the battery, into the fuse box or what. I don't want to use them but if it's my only option...
Suggestions?
Tshane3000 is offline
Old 10-28-2019, 05:39 PM
  #48
DoubleO was in here in Feb 2019, send him a PM , he might be able to answer your enquires
Oldblue is offline
skyline26
11
05-31-2013 07:40 AM
wagoneer
"How To" Tutorial Library
13
03-18-2012 12:57 PM
Double0
Mods - Exterior
20
03-21-2011 08:44 PM
Double0
0
06-21-2008 03:11 AM
NHHHR
25
06-20-2007 08:11 PM
Quick Reply: Custom Headlights w/ LED Angel Eyes & LED Audi DRL
