GPS Mount
I use the window cup and position the unit where the left lower corner just overlaps the flat spot of the boost gage pod ( but not the gage)..found this the best place so its not obstructng and easy to see..and hear too as the speaker bounces off the corner of the dash
I shut the rubber tab on the sucker pad base into the front of my center console compartment. It stays put just fine. In a pinch, my GPS by itself will stay in the slot between the steering wheel and the gauges.
I use both paper, and the navigation on my droid. I have the car cradle for it that I mount on the dash between the A pillar and the cluster. The nice thing about using that set up is that when I use the phone as my audio source, the directions will play through the speakers.
