HHR Baby Moons!
Old 12-27-2016, 10:54 AM
  #51
Part numbers?
Manufacturer?
Those look great!
Are they clipped on?
What did you do to hold them on the wheel?
Oldblue is offline
Old 12-27-2016, 03:07 PM
  #52
patmaher's Avatar
The seller is: Chrome Reverse Baby Moon Hubcaps for Smoothie Wheels - Set of 4 | eBay
I did buy VW clips for 75$ but it never worked with these. i drilled 2 holes in the hubcap lips and 2 in the rims. I jack up the wheel wich allows me to spin the rim and see if the hub cap is centered . I tighten the rear ones with a long wratchet/screwdriver from behind the wheels with screws and nuts (my screw is already glued in the hubcap so it doesn't move). For the front, since the brake disks are bigger i use my fingers thru the rim holes to tighten the 2 screws that i welded a nail over. I also put hockey tape on the hubcap lips so there's no rattles. Works great. Name:  IMG_1314_zpsmjz1leh9.jpg
patmaher is offline
Old 12-27-2016, 03:18 PM
  #53
patmaher's Avatar
I'm building a 2nd set of rims and i found these at a local truck shop for 6.99$ each!!! They are a half inch larger than the E-bays ones i have and also look great on the stock rims. Since there's no lip on these, i cut the side piece off and i'll weld a braket with hole in the back. Maybe the welding will damage the chrome i don't know yet.
patmaher is offline
Old 12-27-2016, 03:19 PM
  #54
Those might work better with the VW clips
Oldblue is offline
Old 12-27-2016, 03:55 PM
  #55
patmaher's Avatar
But the edges are too big. those are for large semi trucks
patmaher is offline
Old 12-28-2016, 12:14 PM
  #56
Lethal Tendencies's Avatar
I took my baby moons off because I couldn't keep them from rusting. I am sure they were a low quality cap,but how do you know whats a good quality
Lethal Tendencies is offline
Old 12-28-2016, 03:07 PM
  #57
patmaher's Avatar
Same here ,i'm in Quebec Canada. My trim rings also rusted. I'll just put em on in the summer.
patmaher is offline
Old 12-29-2016, 07:45 AM
  #58
My moons are ten years old, I don't run them in the winter, but no rust
Oldblue is offline
Old 12-29-2016, 11:07 AM
  #59
patmaher's Avatar
If they are 10 years old then they are senior moons! Mine are still babies after a year.
patmaher is offline
Old 12-29-2016, 12:07 PM
  #60
Daphne Moon is a senior moon
Oldblue is offline
Quick Reply: HHR Baby Moons!
