HHR Baby Moons!
#52
The seller is: Chrome Reverse Baby Moon Hubcaps for Smoothie Wheels - Set of 4 | eBay
I did buy VW clips for 75$ but it never worked with these. i drilled 2 holes in the hubcap lips and 2 in the rims. I jack up the wheel wich allows me to spin the rim and see if the hub cap is centered . I tighten the rear ones with a long wratchet/screwdriver from behind the wheels with screws and nuts (my screw is already glued in the hubcap so it doesn't move). For the front, since the brake disks are bigger i use my fingers thru the rim holes to tighten the 2 screws that i welded a nail over. I also put hockey tape on the hubcap lips so there's no rattles. Works great.
#53
I'm building a 2nd set of rims and i found these at a local truck shop for 6.99$ each!!! They are a half inch larger than the E-bays ones i have and also look great on the stock rims. Since there's no lip on these, i cut the side piece off and i'll weld a braket with hole in the back. Maybe the welding will damage the chrome i don't know yet.
